DC motor drive circuit composed of integrated voltage stabilizing circuit
Source: InternetPublisher:常思一二 Keywords: DC motor drive circuit Updated: 2024/10/14
There are many cases where the motor is driven by an integrated voltage regulator circuit. Unlike the direct drive of a general three-terminal voltage regulator, the circuit in the figure below allows the motor to obtain a driving voltage from 0V to 7V, thus having low-voltage speed regulation performance. IC1 is a fixed voltage regulator with positive output, and IC2 is a four-terminal voltage regulator with adjustable negative output. By adjusting Rl, the motor can obtain zero voltage. Since the heat sink of IC2 is internally connected to the input terminal, IC1 and IC2 can use a common heat sink to adapt to low-voltage operation.
- DIY a simple fire alarm
- Peripheral circuit of automotive motor controller power supply chip
- Homemade Bluetooth controlled car using HC-05 Bluetooth module to communicate with mobile phone
- How to make a wheeled self-balancing robot using ultrasonic sensors
- A small improvement on the ordinary refrigerator motor starting circuit
- Motor control circuit for starting and running without phase loss
- Light-controlled circuit design and analysis
- Design and manufacture of three-phase motor protection circuit
- Electric vehicle battery charging protection circuit
- An experimental model of an infrared radio alarm
- Electric plow control circuit
- Photocell amplification control circuit
- Ringtone control circuit
- sound control circuit
- Multi-pole leakage protector circuit b
- Automatic door detection control circuit
- Timing and fire power control circuit
- Range hood detection control circuit
- Forward and reverse control circuit of micro DC motor b
- Forward and reverse control circuit of micro DC motor a
