Typical recording equalization amplifier circuit
Source: InternetPublisher:笑流年 Keywords: Amplification circuit BSP blocking recorder Updated: 2021/12/23
Balanced amplifier circuits are widely used in electronic products such as recorders . When the recorder is recording, the high-frequency signal must be greatly improved to compensate for the high-frequency loss during the recording process of the magnetic head
; when playing back, since the output of the playback head is proportional to the frequency, the low-frequency output
is weak , so It is necessary to significantly compensate the low-frequency part, and the compensation circuit here is called a balanced amplifier circuit.
Figure 9-9 shows a typical recording equalization amplifier circuit . The preamplified recording signal is sent to
the base of the recording equalization amplifier VT1 through the potentiometer (5 kQ). The amplified signal is output from the collector, and then sent to the recording head through the coupling capacitor, bias magnetic blocking circuit and recording and playback switch.
The high-frequency boosting circuit is located in the emitter circuit of VT1, using an LC series resonant circuit connected in parallel with the 1.2 kfl resistor, so that the highest
gain of VT1 is at the LC resonant frequency, which is used to compensate for the high-frequency loss during the recording process. The blocking circuit prevents the bias signal from affecting the collector
bias of VT1.
- Share a mini piano circuit
- How to use the Arduino tone function to play a melody on a piezo buzzer or speaker
- The easy production of several top-quality tube preamplifiers
- Production of 6n3 Pushing 6p1 Single-ended Tube Amplifier
- Make a pocket amplifier with 8550 and 8050
- Design of a tube amplifier that uses the mains electricity to directly provide screen working power
- DIY a stylish Bluetooth speaker
- 1OW audio power amplifier circuit using UPC1238
- Single power supply audio power amplifier circuit composed of LM3875
- Horseshoe gallbladder preamplifier circuit
- Soil water shortage prompt circuit
- Crabo oscillator circuit
- Capacitive feedback oscillator circuit
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- common emitter amplifier circuit
- superheterodyne radio circuit
- Color display circuit
- Digital stopwatch display circuit
- Small current generator circuit
- Sawtooth wave generator circuit (2)
