Switching regulated power supply circuit of Zhonglong-ZL-2801A DVD player
Source: InternetPublisher:containsmachine Keywords: DVD regulated power supply circuit switching regulated power supply BSP Updated: 2020/08/15
Shown is the switching regulated power supply circuit of Zhonglong ZL-2801A DVD player . It is mainly composed of AC input circuit, rectifier
filter circuit, switching oscillation circuit, switching transformer Tl, secondary rectifier filter and voltage stabilizing circuit. .
1. AC input
circuit The AC input circuit is composed of power switch S, fuse Fl, mutual inductance filter LF and filter capacitors Cl, C2, etc. Its function
is to filter out interference and noise in the AC input signal.
2. Rectifier filter circuit The
220 V AC voltage is filtered and processed by a bridge rectifier circuit composed of bridge rectifier stacks D1~D4 and filter capacitor C3,
and then a DC voltage of about 300 V is output and sent to the ① pin of the switching transformer TI.
- Redundancy principle of power management system, a redundant design strategy in outdoor power BMS
- Sharing layout and tips for multi-rail power supply design
- The basic principles of power supply design. What are the key components of a power supply?
- Benefits of Wide Bandgap Technology for Power Converters
- Use pulse width modulation to get a precise output voltage
- Low cost and high performance LED constant current power supply
- LM317 regulated power supply
- Practical constant current charger-----Constant current charger
- Circuit diagram explanation: simple switching power supply circuit diagram
- Detailed explanation of mobile phone charger circuit diagram
- Pulse therapy circuit
- Particle clogging alarm circuit of wheat seeder
- DC ammeter
- Domestic KD8041 integrated phase locked loop
- Diode Balanced Mixer Circuit
- Double detuned loop frequency discriminator circuit
- Inductive feedback oscillator circuit
- Voltage controlled power supply second-order high-pass filter circuit
- Fault signal trip circuit
- Small current generator circuit
