Application circuit to expand output current
Source: InternetPublisher:宋元浩 Keywords: Application circuit output current three-terminal integration Updated: 2021/09/09
The maximum output current of the currently produced three-terminal integrated devices is 1.5A. If the output current needs to be greater than 1.5A, you can use an external power tube
to expand the output current . The circuit connection is as shown in the figure.
- Build a simple buck-boost regulator and test it on a breadboard
- Energy-saving motorcycle rectifier regulator
- ISO113 circuit that can reduce power consumption
- Isolated two-wire current loop circuit (XTR101, ISO100)
- LED Driver ZD1680
- 0.7~24V continuously adjustable current limiting power supply
- Adjustable voltage power socket
- Converting a lithium battery charging board into a constant voltage and current charger
- MAX1811 Lithium Battery Charger Production
- Circuit diagram explanation: simple switching power supply circuit diagram
- AN6071 application circuit b
- AD594 to 597 basic application circuit b
- OT0001 pyroelectric infrared remote control application circuit
- Switching regulator application circuit composed of W723
- QS7777 application circuit
- YSS247 application circuit
- M69032P application circuit
- AP500 and its application circuit (e)
- STK4036X to 4042X1 typical application circuit
- STKxx series application circuit c
