High efficiency inverter controller circuit
Source: InternetPublisher:狂妄火龙果 Keywords: Inverter control controller circuit field effect transistor BSP Updated: 2020/02/10
Shown is a high-efficiency inverter controller circuit, which is used as a power supply circuit for LCD backlights. This circuit is mainly composed of control
chip Ul (02962G), driving field effect transistor U2, voltage transformer, backlight tube and related circuits constituted.
The +12 V DC voltage sent from the DC power supply supplies power to the integrated circuit Ul and the driving field effect transistor after passing through the filter capacitor Cl; the start
signal (ENA) is sent to the @ pin of U1 to control the start of the inverter circuit. stop. When the power supply of the inverter is normal and the start signal is received,
the ⑩ and @ pins of Ul output the guard-interactive PWM pulse signal, which is amplified by the driving field effect transistor and sent to the
boost transformer. The boost transformer converts the pulse signal to the step-up transformer. The voltage is increased to approximately 800 V to power the backlight tube.
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- Energy-saving motorcycle rectifier regulator
- ISO113 circuit that can reduce power consumption
- Isolated two-wire current loop circuit (XTR101, ISO100)
- Driving circuit that controls LED brightness using PWM signal
- Parallel DC regulated power supply circuit diagram
- Principles and precautions of active discharge circuit
- Current/voltage conversion circuit using current converter
- Voltage-current converter constructed with XTR110
- LM317T voltage regulation adjustable circuit diagram explanation
- Motor forward and reverse control wiring diagram (2)
- Electronic anti-asthma circuit
- Physiotherapy ventilator circuit
- Agricultural spraying and insecticide control circuit
- Biogas concentration detection line
- Domestic KD8041 integrated phase locked loop
- Junction field effect transistor mixer circuit
- Proportional frequency discriminator circuit
- Diode balanced amplitude modulation circuit
- Double gate field effect transistor high frequency amplifier circuit
