Laptop memory power supply circuit (0.9-1.8V)
Source: InternetPublisher:走马观花 Keywords: Power supply circuit laptop computer BSP Updated: 2020/03/23
Shown is the memory power supply circuit of a notebook computer , which uses SC486 as the power management chip.
There are two sets of PWM signal generation circuits in the SC486 chip. One set outputs two PWM signals with opposite phases from the @ pin and the @ pin, which
are added to the gates of the Ql and Q2 field effect transistors respectively, so that the two field effect transistors are turned on alternately. Convert the battery's supply voltage (9 V-19 V)
into a pulse voltage, and then filter it through Ll, C13, and C14 to +1.8 V (10 A) to power the memory. At the same time, the +1,8 V power supply is added
to the @ pin and @ pin of SC486. There is a second set of PWM signal generation circuits and two field effect transistors inside the chip. These two field
effect transistors turn the 1.8 V voltage into a pulse signal, which is output by the ⑩ and @ pins of SC486. After filtering by C15 and C16, it outputs a 0.9 V
DC voltage to power the circuit in the memory .
- 5 Converter Topologies for Integrated Solar and Storage Systems
- Schematic diagram of car cigarette lighter to USB power port
- Fabrication of multi-cell lithium battery charging circuit
- Introduction and principle analysis of switching regulated power supply
- Transformerless AC-DC constant current LED driver circuit
- Using CW34603 to form a circuit to change the polarity of the output power supply
- An ultra-low output voltage regulator
- 3~15V 10A adjustable voltage regulated power supply
- Car Audio Power Supply
- Adjustable voltage regulated power supply circuit
- Pulse therapy circuit
- Physiotherapy ventilator circuit
- Particle clogging alarm circuit of wheat seeder
- DC ammeter
- Simple AGC circuit in transistor radio
- Diode square rate detection circuit
- common emitter amplifier circuit
- color discrimination circuit
- Motorcycle flash light circuit
- Home appliance repair signal generator circuit
