Step-up 3.5V voltage stabilizing circuit
Source: InternetPublisher:闪电杰克 Keywords: Voltage stabilizing circuit boost type DC voltage power supply Updated: 2021/07/08
This chip can be used to build a boost or stabilized
power supply to convert a DC voltage of 2 V to 3.2 V into a DC voltage of 3.5 V.
- What kind of circuit is a voltage regulator circuit?
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Driving circuit that controls LED brightness using PWM signal
- Constant current LED lamp driver circuit with soft start and anti-shock
- Boost drive circuit composed of RT8450
- Charging control circuit made by solar energy
- A small and easy-to-make fast charger
- MIC4680 constant current charger
- Practical constant current charger-----Constant current charger
- A low-cost, high-reliability battery charger for electric vehicles
- Is the power module usually called a power supply?
- Analysis of the advantages and disadvantages of electrolytic capacitor-free LED power supply
- What is the general technical route for reducing stroboscopic flicker during the de-powering process of LEDs?
- Power transformer use
- Automatically set timer
- AD596-597 functional diagram
- Li-ion battery charger composed of MAX1757
- Electronic power saving mousetrap circuit
- Application circuit of LT3468 dual output boost LED driver
- Boost-type voltage stabilizing circuit diagram using MC34063 series
