Power failure protection circuit
Source: InternetPublisher:天天都吃好吃的 Keywords: Power failure protection circuit RAM BSP Updated: 2021/11/12
![<strong>Power failure protection circuit</strong>](http://www.eeworld.com.cn/circuit/upload/c169b9fe9c1923da1c0bc8327c3f48de/661b3996e50fd89df3991cb2f9021746.jpg)
In order to prevent data loss caused by sudden power outage or power supply voltage reduction, a power outage protection circuit is used . A voltage comparator LM339 is used in the circuit to monitor the supply voltage. It can be seen from the figure that the reverse input pin 4 is provided by R3 and VL to provide a stable standard voltage of 1.8V. The forward input pin 5 is used as the voltage sampling input terminal of the power supply system. If the voltage of pin 5 is lower than 1.8V, LM339 Pin 2 of the chip output terminal outputs a low level to block the chip select CS of the RAM , and the RAM stops working. The B+ output is a high level to provide the operating voltage to maintain the RAM .
- How to Make a Soft Latch Circuit
- Schematic diagram of car cigarette lighter to USB power port
- Single-power supply circuit for ISO122P/ISO124
- How to use SBR to improve power conversion efficiency
- Using CW34603 to form a circuit to change the polarity of the output power supply
- Dual forward converter schematic diagram
- A small and easy-to-make fast charger
- 0.7~24V continuously adjustable current limiting power supply
- UC3842 Electric Vehicle Charger
- A low-cost, high-reliability battery charger for electric vehicles
- Motor forward and reverse control wiring diagram (2)
- Inpatient pager circuit
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- Domestic KD8041 integrated phase locked loop
- Diode Balanced Mixer Circuit
- Capacitive feedback oscillator circuit
- Power phase sequence display circuit
- Motorcycle flash light circuit
- Sawtooth wave generator circuit (2)
- Sawtooth wave generator circuit (1)
