AX-320 DC arc welding machine circuit
Source: InternetPublisher:同住地球村 Keywords: Arc welding machine electromechanical Updated: 2021/02/01
Rotary DC arc welding machines include AX, AX1, AX3 and AR series. Its structure is basically the same, and it is
an integral converter unit composed of a three -phase asynchronous motor and a DC arc welding generator coaxially.
The current adjustment of AX series DC arc welding machine has two types: coarse adjustment and fine adjustment. The coarse adjustment has three positions and is fixed in the groove of the machine cover
. It is realized by moving the brush holder. If the brush holder is moved in the direction of the motor, the working current will decrease; on the contrary, the working current
will increase. Fine adjustment is achieved by changing the resistance of the varistor in the shunt winding via a handwheel.
The current adjustment of AX1 series DC arc welding machine has two types: coarse adjustment and fine adjustment. Coarse adjustment is
achieved by changing the number of turns of the series winding on the line board . Fine adjustment is achieved by changing the resistance of the transformer in the shunt winding via a handwheel. The current adjustment of
AX3 series DC arc welding machine has two types: coarse adjustment and fine adjustment. There are two levels of coarse adjustment,
realized by a single-throw switch with large and small marks . Fine adjustment is achieved by moving the brushes with a hand wheel. The change of polarity can
be achieved by pulling the double-throw switch with "reverse" and "forward" marks .
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- ISO113 circuit that can reduce power consumption
- Simple and practical LED lamp driving circuit
- The constant current source composed of two transistors can drive high power
- LED rechargeable flashlight circuit diagram
- Parallel DC regulated power supply circuit diagram
- Dual forward converter schematic diagram
- Integrated regulated power supply with continuously adjustable output voltage
- Homemade Electric Bike Fast Charger
- Detailed explanation of mobile phone charger circuit diagram
- Physiotherapy ventilator circuit
- Fan motor starting circuit diagram
- Schematic diagram of current direction and coil rotation direction of DC brush motor
- Three-phase induction motor circuit schematic using starting compensator
- Digital camera-DV machine power supply circuit
- GZ-600 argon arc welding machine circuit-02
- BX2 series AC arc welding machine circuit d
- BX2 series AC arc welding machine circuit a
- KGCA-15-0-165 thyristor charger circuit
- GCA-30 (0-36, 0-72) silicon rectifier charger circuit
