Cut-off tube controlled discharge delay circuit
Source: InternetPublisher:王达业 Keywords: Delay circuit BSP potential Updated: 2020/08/19
8. Cut-off tube controlled discharge delay circuit
Compared with the discharge delay circuit and the charging delay circuit, the discharge delay circuit can obtain a longer delay, and the delay
accuracy is relatively high.
The circuit is shown in the figure, which is a schematic diagram and a waveform diagram of input and output.
Under normal circumstances, when there is no signal input, the transistor VTi is turned off, VT2 and VTa are turned on, and U is output. . is zero potential .
When U9r signal voltage makes VTi conductive, VT2 is cut off, VT3 is still conductive, U. . is zero potential. After a delay,
VT2 is turned on, VT3 is turned off, and U is output. . is a high potential. When the input signal disappears, VTi returns to cut-off, and VT2 and
VT3 are turned on.
The Usr signal appears to U. . The time interval between becoming high potential is the delay time £, t can be calculated according to the following formula:
t=O. 7(Rs+RP)C (s)
In the formula, the unit of R5 and RP is 0, and the unit of C is F .
- Analysis of the working principle of the sound and light controlled delay switch circuit
- How to choose the right level of integration to meet motor design requirements?
- What is a RADAX motor?
- Introduction to the internal structure of the Delta winding motor
- Design and analysis of wire control circuit
- Design and analysis of the principle of automatic power-off switch during power outage
- Design and production of wireless multi-location control switch circuit
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
- Ultra-short wave item left behind reminder alarm
- Homemade anti-theft watchdog
- Motor forward and reverse control wiring diagram (2)
- Ultrasonic blind pathfinder circuit
- Homemade disinfectant circuit
- Fish pond oxygenation reminder circuit
- Greenhouse temperature control circuit
- Simple AGC circuit in transistor radio
- Differential Amplifier Circuit
- superheterodyne radio circuit
- Color display circuit
- Fault signal trip circuit
