Cut-off tube control charging delay circuit
Source: InternetPublisher:3228 Keywords: Delay circuit BSP Updated: 2020/10/03
Under normal circumstances, when there is no signal input, the transistor VTi is cut off. VTz is turned on and U is output. is low potential. When U. ,
when the signal voltage turns VTi on, VTz turns off and Us is output. is a high potential. When the Ua signal disappears, VTi is cut off,
VTz is turned on, and U. . Returns to low potential again. From U. , the signal appears to U;. The time interval between changing to high potential is the delay
time of the circuit. £ can be calculated according to the following formula:
z =RCln poison (s)
where U MN - voltage regulator tube vs changes from conduction to cut-off, the voltage between M and N, V.
When UMW/E. When -0.37, t-RC, the time characteristics are relatively stable, and the longest delay t can be obtained. . . .
- Tutorial on making your own remote-controlled robotic arm
- Build a Smart Garage Door Opener Using a Raspberry Pi
- How to Make a Simple Chicken Incubator
- What is a RADAX motor?
- Motor self-starting circuit
- Methods for Eliminating Noise of Brushed DC Motors
- Hydraulic control circuit design and analysis
- Design and production of wireless multi-location control switch circuit
- Amplitude and phase detection leakage protection device designed and manufactured using PIC16C711A
- PIC microcontroller controlled remote anti-theft alarm circuit
- Rural vegetable greenhouse lighting circuit
- collector amplitude modulation circuit
- Diode balanced amplitude modulation circuit
- Inductive feedback oscillator circuit
- Second-order active band-stop filter circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
- superheterodyne radio circuit
- High and low frequency signal generator circuit
- Three primary color display circuit
- Power phase sequence display circuit
