The simplest three-phase thyristor charger circuit
Source: InternetPublisher:newrudeman Keywords: Charger thyristor electromechanical Updated: 2021/12/22
This circuit uses a thyristor to achieve three-phase half-wave controllable voltage regulation. It does not require a synchronous
transformer and can regulate the conventional charging current of 170-230V batteries. This circuit uses the potential of the charged battery to
turn off the thyristor . The working condition of the circuit is that the battery potential must be greater than or equal to half of the secondary phase voltage peak value.
- Introduction and principle analysis of switching regulated power supply
- Use pulse width modulation to get a precise output voltage
- The constant current source composed of two transistors can drive high power
- Current/voltage conversion circuit using current converter
- Voltage-current converter constructed with XTR110
- A simple positive and negative power supply circuit
- Dynamic power supply for power amplifier controlled by thyristor
- Homemade low-power UPS
- Design of electric vehicle charger
- Converting a lithium battery charging board into a constant voltage and current charger
- Resistance furnace drive and measurement circuit
- Thyristor resistance-capacitance protection circuit b
- Voltage controlled sawtooth oscillatora
- Voltage controlled sawtooth oscillatorb
- Thyristor cut-off delay circuit part 5
- The simplest three-phase thyristor charger circuit
- Multi-speed constant current charger circuit
- Charger circuit
- GCA 20A/180V silicon rectifier charger circuit
