Simple battery charging and discharging automatic control device circuit
Source: InternetPublisher:toothache Keywords: Device circuit battery charging and discharging BSP relay Updated: 2020/05/12
For some batteries used to power fixed equipment, if an automatic control device as shown in Figure 10-20 is installed,
maintenance work can be greatly facilitated. When the battery is discharged to a specified value, the device can automatically disconnect the load to stop power supply, and switch to the charger to
charge the battery; when the battery is charged to a specified value, it will automatically stop charging and connect the load to power supply.
In the figure, the relay
KA can be a JQX-4F type, DC 12V sensitive relay. It
can pull in when the working voltage exceeds 8V , so there is no need to worry about the relay not being able to pull in when the battery voltage is 11. SV.
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- 220V Remote Load Monitor
- Single-power supply circuit for ISO122P/ISO124
- Driving circuit that controls LED brightness using PWM signal
- LED Driver ZD1680
- Detailed explanation of 5v charger circuit diagram
- 3~15V 10A adjustable voltage regulated power supply
- Car power 1.5V-12V six-speed converter
- A low-cost, high-reliability battery charger for electric vehicles
- LM317T voltage regulation adjustable circuit diagram explanation
- electromagnetic field sensor
- Voice controlled flash LED light circuit diagram
- Peanut and melon seeds roasting machine circuit
- Poultry warming temperature control circuit
- Farmland irrigation automatic control circuit b
- base amplitude modulation circuit
- Capacitive feedback oscillator circuit
- Double gate field effect transistor high frequency amplifier circuit
- Digital stopwatch display circuit
- Sawtooth wave generator circuit (1)
