Examples of OFDM modulation systems
Source: InternetPublisher:狂妄火龙果 Keywords: Modulation system OFDM modulation BSP Updated: 2020/10/08
Example of OFDM modulation system . As can be seen from the figure, the input data signal (...---Ol01100)
is serialized and converted to separate the input signal into "00", "ll", "10", "00", and "01" "Waiting for data.
The separated data is then subjected to forward-varying modulation to form amplitude components of , and Q respectively on the time axis. These signals are subjected to
inverse discrete Fourier transformation in IDFT . After conversion, the Q signal and Q signal are converted to parallel/serial respectively, and then two orthogonal Q and Q serial signals are output .
- Voltage divider circuit calculation formula, where to find the voltage divider circuit?
- How are diodes made using semiconductors?
- What is a pure resistance circuit? What is a pure resistance AC circuit?
- Why Do Amplifier Fuses Blow? How Do You Prevent Amplifier Fuses from Blowing?
- Datasheet/Pinout/Technical Specifications of LMC555
- Simple Wired Spy Bug Circuit Built Based on IC741
- Introduction of TDA4863J/4863AJ TV field scanning IC
- Experiment and production of NE555 time base integrated circuit
- Common electrical circuits: frequency-selective (bandpass) amplifier circuit
- Circuit diagram of a differential amplifier circuit
- Motor forward and reverse control wiring diagram (2)
- Motor overcurrent protection circuit
- stuttering correction circuit
- Electric massager circuit
- Frequency modulator composed of NE566
- base amplitude modulation circuit
- collector amplitude modulation circuit
- Audio function generator composed of ICL8038
- Differential Amplifier Circuit
- Sawtooth wave generator circuit (1)
