Analog-to-digital converter application circuit design analysis
Source: InternetPublisher:小胖友 Keywords: Analog to Digital Converter Updated: 2023/12/15
An analog-to-digital converter, or ADC for short, usually refers to an electronic component that converts analog signals into digital signals. A typical analog-to-digital converter converts an input voltage signal into an output digital signal. This article introduces the circuit principles of several analog-to-digital converter chips.
1. AD9280
The AD9280 device is a single-chip, 8-bit, 32 MSPS analog-to-digital converter (ADC). This article mainly introduces the AD9280 features, application range, reference design circuit and circuit analysis to help you shorten design time.
AD9280 introduction:
The AD9280 is a single-chip, 8-bit, 32 MSPS analog-to-digital converter (ADC) that operates from a single supply and includes an on-chip sample-and-hold amplifier and voltage reference. It uses a multi-stage differential pipeline architecture with a data rate of 32 MSPS and no missing codes over the entire operating temperature range.
AD9280 features:
Pin compatible with AD876-8
Power consumption: 95 mW (3 V power supply)
Operating voltage range: +2.7V to +5.5V
Differential nonlinearity (DNL) error: 0.2 LSB
Power saving (sleep) mode
AD9280 internal structure block diagram:
Figure 1 Internal structural block diagram of AD9280, showing the internal structure
AD9280 reference design circuit:
Figure 2 AD9280 typical application circuit
2.AD7541
The AD7541 device is a low-cost, high-performance 12-bit single-chip multiplying digital-to-analog converter. This article mainly introduces the AD7541 characteristics, application range, reference design circuit and circuit analysis to help everyone shorten design time.
AD7541 introduction:
The AD7541A is a low-cost, high-performance 12-bit single-chip multiplying digital-to-analog converter. The device is manufactured using advanced low-noise thin film CMOS technology and is available in standard 18-pin DIP and 20-pin surface mount packages. The AD7541A is functionally and pin-compatible with the industry standard device AD7541, and has improved specifications and performance. Additionally, improvements in device design ensure that latch-up does not occur, eliminating the need for output protection Schottky diodes.
AD7541 features:
Improved version of AD7541
Complete four-quadrant multiplication
12-bit linearity (endpoint)
All devices are guaranteed to be monotonic
TTL/CMOS compatible
low cost
No protection Schottky diode required
Low logic input leakage
AD7541 internal structure block diagram:
Figure 3 Internal structural block diagram of AD7541, showing the internal structure
AD7541 reference design circuit:
Figure 4 AD7541 typical application circuit
3.AD7694
The AD7694 device is a 3-channel, low-noise, low-power consumption, 24-bit Σ-Δ ADC with a built-in on-chip instrumentation amplifier. This article mainly introduces the AD7694 characteristics, application range, reference design circuit and circuit analysis to help you shorten the design time. .
AD7694 introduction:
The AD7694 is a 16-bit, 250 kSPS, charge redistribution, successive approximation analog-to-digital converter (ADC) operating from a single 2.7 V to 5.25 V supply (VDD). The device contains an extremely low-power, high-speed, 16-bit no-missing-code sampling ADC (Grade B), an internal conversion clock, and an SPI-compatible serial interface port. It also integrates a low-noise, wide-bandwidth, extremely short aperture delay sample and hold circuit. On the rising edge of CNV, the AD7694 samples the analog input voltage difference between IN+ and IN-, ranging from 0V to REF. The reference voltage (REF) is provided externally and can be set up to the supply voltage.
AD7694 features:
16-bit resolution
Throughput: 250 kSPS
Integral nonlinearity (INL): ±4 LSB maximum
Power consumption:
800 µA @ 5V/100kSPS
540 µA @ 2.7V/100kSPS
Pseudo-differential analog input range: 0 V ~ VREF (VREF is up to VDD)
AD7694 applications:
battery powered equipment
Medical equipment
mobile communications
personal digital assistant
data collection
Instrumentation
process control
AD7694 reference design circuit:
Figure 5 AD7694 typical application circuit
- An example of LC oscillation circuit
- A relatively complete ultrasonic generator circuit
- Ultra-high frequency voltage-controlled oscillator constructed with UPC1651
- Sine wave to square wave converter circuit diagram analysis
- Analog-to-digital converter application circuit design analysis
- Inexpensive high-precision digital clock time base circuit
- 10/1 frequency range function oscillator
- Pulse edge selection circuit
- Voltage to frequency conversion circuit
- 48MHz HCMOS oscillator circuit
