Wiring of lightning protection belts, voltage equalizing rings, etc. in high-rise buildings
Source: InternetPublisher:elleny Keywords: Wiring BSP grounding Updated: 2020/01/06
Wiring of lightning protection belts and voltage equalizing rings
Lightning protection belts and voltage equalizing rings should be installed between the floors of high-rise buildings,
connected to the roof lightning protection network, and connected to the grounding
device through down conductors, as
shown in Figure 20-30. For the first type of building, L<12m (
area with strong lightning activity) and L<18m (area with normal lightning activity); for the second
type of building, L<24m.
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- Introduction and principle analysis of switching regulated power supply
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- Constant current LED lamp driver circuit with soft start and anti-shock
- LED Driver ZD1680
- Using CW34603 to form a circuit to change the polarity of the output power supply
- Voltage-current converter constructed with XTR110
- An ultra-low output voltage regulator
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- Ultrasonic blind pathfinder circuit
- Varactor Diode Frequency Modulator
- Parallel crystal oscillator
- Crabo oscillator circuit
- Differential Amplifier Circuit
- Voltage controlled power supply second-order high-pass filter circuit
- High and low frequency signal generator circuit
- Digital stopwatch display circuit
- Various signal generator circuits
- Sine wave signal generator circuit
