Wiring c of leakage protectors with different action modes
Source: InternetPublisher:同住地球村 Keywords: Wiring earth leakage protector BSP fuse Updated: 2021/08/28
Wiring of leakage protectors with different action modes
① Electromagnetic leakage protector. Because it is not protected against overload and short circuit, a fuse must be installed in front of it .
The wiring of the electromagnetic leakage protector is shown in Figure (a). In the figure, os is the isolating switch or knife switch.
②DZL18, DZL33 and DLK type leakage protectors are electronic leakage protectors with controlled power supply. Because they do not
have overload protection function, the fuse must be installed behind it. The wiring of this type of leakage protector is shown in Figure (b).
If the fuse is installed in front of it, once an overload or short circuit occurs, the phase line fuse does not break but the neutral line fuse blows, and the leakage
protector will not trip. At this time, the human body will get an electric shock if it touches the phase line on the load side. ③ For leakage protectors (bias circuit breakers, such as DZL30, XA10LE, E4EB,
etc. series)
with both overload and short-circuit protection functions , there is no need to install a main fuse . The wiring is shown in Figure (c).
- In-depth analysis of DC-AC converter inverter
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Visible laser digital control modulation driver
- How to use SBR to improve power conversion efficiency
- Dual forward converter schematic diagram
- Dynamic power supply for power amplifier controlled by thyristor
- Homemade low-power UPS
- Integrated regulated power supply with continuously adjustable output voltage
- Electric bicycle battery charger circuit
- LM317T voltage regulation adjustable circuit diagram explanation
- Set timing circuit when power is on
- Electronic anti-asthma circuit
- High-efficiency speaker circuit for rural stage
- Crop anti-frost circuit
- Agricultural spraying and insecticide control circuit
- Soil water shortage prompt circuit
- collector amplitude modulation circuit
- Parallel crystal oscillator
- Voltage-controlled voltage source second-order active low-pass filter circuit
- High and low frequency signal generator circuit
