stage smoke circuit
Source: InternetPublisher:拳制龙 Keywords: Hydraulic wireless remote control Updated: 2021/06/16
Stages, discos, karaoke halls and other cultural and entertainment venues are equipped with a wide variety of stage effect equipment, such as stage lighting, bubble machines, snow machines, salute machines, gas machines, etc., in order to add atmosphere to the performances and enhance the performance effects. Pillars, etc., smoke machines are also one of the common stage effect devices.
The working principle of the circuit is as follows: Before the stage smoke circuit is planned to be used in a program, special e-liquid should be added in advance (or the internal container has pre-stored e-liquid). And before the performance starts, the smoke machine must be powered on to preheat. The length of preheating time should be specified to be above 8mrn. If the preheating time is insufficient, the spray will not be turned on. After the preheating is completed, the "spray" control will be started in time. A wireless remote control receiving controller plugged into the main unit of the hood and a wireless remote control in the operator's hand will be used. corresponding control .
After the remote control sends a wireless command, an FM receiving module in the external controller circuit of the smoke machine receives the command signal pulse. After processing, it is output from the "OUT" pin to the @ pin of the demodulation integrated block lCl. The IC 1 circuit has functions such as amplification, detection and shaping. After processing, a high-level control voltage signal is output from the @ pin of IC1. This voltage drives VT1 to conduct through the VD1 diode, and the light-emitting diode in the optocoupler IC2 emits light; after the photosensitive trigger tube in IC 2 is turned on, the thyristor VTH is triggered to conduct. Then a small hydraulic pump on its circuit started running. The hydraulic pump draws out the smoke oil and sprays it out in the form of smoke through the heater. The actual spray duration is still controlled by the operator using the wireless remote control in his hand, as shown in the figure.
- Detailed explanation of the working principle of the clapper activated optical circuit
- A simple device activator circuit
- Share a solar beacon circuit
- Build an Automatic Candy Vending Machine
- Using BMP280 to make a weather station
- How to convert digital values into analog values by connecting MCP4725 with Arduino
- How to Make a Digital Taxi Meter Using Arduino
- How to Use the Radio to Record Phone Calls Automatically
- Automatic recovery electronic fuse with soft start function
- How to use ultrasonic sensors to make a simple nucleic acid sampling machine
- stage smoke circuit
- M7130 horizontal axis rectangular table surface grinder control circuit
- Hydraulic rotary table control circuit 02
- Hydraulic rotary table control circuit 01
- Duty cycle wireless remote control circuit diagram
- Homemade wireless remote control circuit diagram
- Use electric contact pressure gauge to make hydraulic and pneumatic automatic control circuit
- Interlock control circuit of drilling machine spindle motor and hydraulic motor
- Interlock control circuit diagram of hydraulic motor of spindle motor on drilling machine
- How does an optocoupler work? Introduction to the working principle and function of optocoupler
