SL323 level drive display circuit and pin arrangement
Source: InternetPublisher:newlandmark Keywords: Display circuit BSP Updated: 2020/12/04
This circuit uses fluorescent indicator tube display. Its purpose is the same as the SL322C circuit.
Circuit features:
① The operating voltage range is 12 -20V;
② It can directly drive fluorescent level display tubes, and its driving voltage interval remains linear (0.7V).
Main electrical parameters: Maximum power supply voltage is 24V; power supply current ≤ImA (input is zero) and ≤40mA (input
is 5.5V); lighting level ≤lV (the first line is on) and ≤5.5V (all ten lines are on) ); the input impedance is 20kn.
The SL323 level drive display circuit and pin arrangement are as shown in the figure
- What is the function of a voltage regulator in a circuit? How to connect a voltage regulator?
- Which TVS diodes are suitable for RS232/RS485 and Controller Area Network applications?
- This article will tell you the hard requirements of operational amplifiers
- Advantages and disadvantages of organic semiconductors, the conductive mechanism of organic semiconductors
- How do you calculate the value of capacitors in series? Why use capacitors in series?
- Beautiful crown wreath made with LED
- Share an interesting LED decoration project
- How to install the accelerometer
- Structural diagram and function of sliding resistor
- Common electrical circuits: frequency-selective (bandpass) amplifier circuit
- Voice controlled flash LED light circuit diagram
- Inpatient pager circuit
- Egg warming circuit
- Chicken supplementary light to increase egg production rate circuit
- Parallel crystal oscillator
- Schiller oscillator circuit
- Capacitive feedback oscillator circuit
- Second-order active band-stop filter circuit
- Voltage controlled power supply second-order high-pass filter circuit
- color discrimination circuit
