Universal digital display counter circuit
Source: InternetPublisher:酷到被通缉 Keywords: Digital display counter circuit BSP photoelectric switch Updated: 2021/05/23
The universal digital display counter is capable of completing various
functions It also has the functions of counting, rechecking, registering, sending numbers, controlled extinguishing, invalid zero extinguishing, BCD code information output, etc. Multifunctional
assembly. It can be used directly or through interfaces with various integrated circuits such as TTL, CMOS, and ECL. For counters used in factories, etc.
, the assembly only needs to be assembled with a universal photoelectric switch
or proximity switch.
The general counter circuit is shown in Figure 15-56. The SX-22-S10 in the picture is a reflective photoelectric switch . It can also be a projection type
or use various proximity switches, or simply use a mechanical switch.
- Why do we need a MOSFET gate resistor? MOSFET Gate Resistor Placement
- The Importance and Ideal Model of Impedance Matching
- What are the main types of resistors? Detailed explanation of the functions and uses of resistors
- RC filter explained in detail
- Beautiful crown wreath made with LED
- How to build a drag racing timer circuit using a 7-segment display and discrete components
- Share a Motorola amplifier circuit
- How to install the accelerometer
- Using an Op Amp to Drive a Simple and Practical Power Amplifier
- FL52C4 induction electronic greeter
- strain sensor
- Analysis of rectifier circuit types and principles
- stuttering correction circuit
- Pulse therapy circuit
- Agricultural temperature control circuit
- AC voltmeter
- Diode Balanced Mixer Circuit
- Double detuned loop frequency discriminator circuit
- Three primary color display circuit
- Sine wave signal generator circuit
