output circuit
Source: InternetPublisher:newrudeman Keywords: BSP transistor amplifier Updated: 2021/03/12
It is the intermediate link between the current regulator and the trigger. The outputter is a two-stage amplifier
with deep negative feedback, positive offset and upper and lower limiting. Its voltage amplification factor
is 1, and its current amplification factor is the product of the two transistor amplification factors, so it has a large output current. Its output characteristics
are shown in Figure 16-77 (b).
Adjust potentiometers RPi and RP2. The operating points of transistors VTi and VT2 can be changed ,
and the maximum and minimum values of the output voltage can be changed by adjusting RP3 and RP4.
- Tutorial on making your own remote-controlled robotic arm
- How to Make a Simple Chicken Incubator
- What are the challenges in designing a permanent magnet linear generator?
- Introduction to the internal structure of the Delta winding motor
- Replace the GE LOGIQ a200 ultrasound measurement key with a self-made touch switch
- Manual automatic air compressor control circuit
- Working principle of one Xipu STR soft starter controlling two motors
- Motor self-starting circuit
- Bicycle anti-theft alarm
- "Watchdog" anti-theft alarm circuit
- Agricultural spraying and insecticide control circuit
- Greenhouse temperature control circuit
- Mixer built with analog multipliers
- Diode balanced amplitude modulation circuit
- Series crystal oscillator
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Double gate field effect transistor high frequency amplifier circuit
- Second-order active band-stop filter circuit
- Three primary color display circuit
- Digital stopwatch display circuit
