Low-voltage circuit breaker (electromagnetic closing) mutual switching circuit for dual power supply
Source: InternetPublisher:柯南道尔 Keywords: Low voltage circuit breaker power supply electromagnetic Updated: 2020/04/26
Dual power supply mutual transfer and self-restoration means that the load is powered by two power supplies at the same time. When one of the power supplies fails, the tie switch automatically
closes and the uninterrupted loop power supply bears the entire load. When the power supply to the power outage circuit is restored , the contact switch automatically trips and returns
to the original power supply mode. The circuit is as shown in the figure
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- ISO113 circuit that can reduce power consumption
- Recommended circuits for different power on times of LM4911
- LED Driver ZD1680
- Low cost and high performance LED constant current power supply
- Dynamic power supply for power amplifier controlled by thyristor
- A small and easy-to-make fast charger
- Adjustable regulated power supply with current limiting protection
- What are the design specifications for FPGA power supply design?
- How to suppress power supply noise?
- Summary of key points of switching power supply PCB layout, worth collecting!
- Why is the scrapped volume of electric vehicle batteries so much higher than predicted?
- Machines are rare, hackers can actually steal data through the power supply
- Do you know how to select the IC chip of the power adapter?
- Do you know the possible reasons why the power adapter cannot be used universally?
- EMC design component selection and circuit design are critical
- Automatic power shut-off circuit
- Low voltage circuit breaker protection circuit e
