Machines are rare, hackers can actually steal data through the power supply
Source: InternetPublisher:兰博 Keywords: power supply Updated: 2020/05/02
Did you know that hackers can also use tools to steal data through power supply? Nowadays, many companies or institutions will physically disconnect extremely important computers from the Internet in order to prevent important data from being leaked. This can also be said to ensure that computer data is not leaked. One of the ultimate ways to get stolen by hackers. However, in theory, this method is not safe for insiders who want to steal confidential data, and this is why companies continue to strengthen internal security monitoring.
Image source: Cyber Security Labs @ Ben Gurion University
Recently, a foreign network security research institution discovered a method that can steal resources from a computer when it is completely physically disconnected from the network. The method called POWER-SUPPLaY discovered by Dr. Mordechai Guri of the Cyber Security Research Center of Ben Gurion University in Israel, as the name suggests, transmits data to the outside through the ultrasonic waves of the computer power supply.
The specific method involves a piece of malware that changes the load on the CPU, as well as a mobile phone. By changing the load of the CPU, the ultrasonic frequency of the power supply will also change accordingly, and mobile phones that are no more than 5 meters away can receive these ultrasonic waves, thereby achieving the purpose of transmitting data.
Of course, this method also has quite a few limitations, including the need to run malware or code on the computer, the need to have a mobile phone nearby, and the 50 bits per second transmission speed means that it can only transmit a maximum of about 10,000 words per hour. Simple It is very difficult to implement and requires knowing what the target file is and where it is.
In fact, this is not the first method discovered by Dr. Mordechai Guri that can steal data when the Internet is physically disconnected. Previously, he also developed Air-ViBeR, a method that uses specific vibrations from a speed-adjustable fan in the chassis to transmit data. However, this method is less efficient because it requires a mobile phone to convert the received vibrations into 1s and 0s. .
- Basic characteristics of power field effect tubes, how to improve the dynamic performance of power MOSFET
- 220V Remote Load Monitor
- Basic connection circuit of signal and power supply composed of ISOll3
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Use pulse width modulation to get a precise output voltage
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- Miniature polarity reversal power supply using MAX1721
- A low-cost, high-reliability battery charger for electric vehicles
- Circuit diagram explanation: simple switching power supply circuit diagram
- Homemade home inverter circuit diagram
- Summary of key points of switching power supply PCB layout, worth collecting!
- How to ensure that the power supply works efficiently for a long time?
- How to judge the quality of LED power supply?
- Which power supplies should be chosen for collection?
- Power phase failure display circuit
- Miniature polarity reversing power supply composed of MAX1721
- Medical infusion alarm circuit
- Power outage alarm circuit
- AD597 functional diagram
- Power circuit b composed of intelligent thyristor modules
