Dual power supply mutual transfer and reset circuit
Source: InternetPublisher:桂花蒸 Keywords: switch Updated: 2020/08/30
Dual power supply mutual transfer and self-restoration means that the load is powered by two power supplies at the same time. When one of the power supplies fails, the tie switch automatically
closes and the uninterrupted loop power supply bears the entire load. When the power supply to the power outage circuit is restored , the contact switch automatically trips and returns
to the original power supply mode. The circuit is as shown in the figure
- Basic connection circuit of signal and power supply composed of ISOll3
- Op amp power supply decoupling bypass measures
- Use pulse width modulation to get a precise output voltage
- Transformerless AC-DC constant current LED driver circuit
- Simple and practical LED lamp driving circuit
- LNK304 non-isolated LED light string driver circuit
- CNC regulated power supply production
- Electric bicycle battery charger circuit
- Mc34063 MP3 Switching Charger
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- Causes of inductor whistling in DC/DC circuits and related solutions
- Principle circuit of current switching class D amplifier
- Improve lighting power factor circuit
- Instantaneous water heater automatic constant temperature experimental circuit diagram
- Using 74LS244 to expand 24-channel input interface circuit
- Switching interface circuit in timing query mode
- Single pulse signal generating circuit h
- Lithium battery charger circuit
- DDR memory power supply circuit
- One of the long delay circuits using integrated circuits
