One of the regulated power supply circuits with over-current and short-circuit protection
Source: InternetPublisher:已注销 Keywords: Short circuit protection regulated power supply circuit BSP Updated: 2020/03/10
This circuit cannot automatically resume operation after the fault is eliminated. To resume work,
press the reset button SB.
The output voltage of the voltage regulator can be adjusted in the range of 0.2~15V through the potentiometer RPz, and the maximum load current (which
can play a protective role under this current) can be determined by adjusting the trimming resistor RPi. When the VTs is installed with a heat sink and the output voltage
is 15V, the voltage regulator can pass a current
of 1A for a long time , or 2~3A for 30-40min (depending on the
air convection conditions of the tube radiator).
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Driving circuit of switching power supply field effect tube
- Energy-saving motorcycle rectifier regulator
- Parallel DC regulated power supply circuit diagram
- Dual forward converter schematic diagram
- Boost drive circuit composed of RT8450
- Homemade low-power UPS
- Converting a lithium battery charging board into a constant voltage and current charger
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- Detailed explanation of mobile phone charger circuit diagram
- Set timing circuit when power is on
- Voice controlled flash LED light circuit diagram
- Bone hyperplasia treatment circuit
- Electric massager circuit
- Domestic KD8041 integrated phase locked loop
- Crabo oscillator circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Differential Amplifier Circuit
- color discrimination circuit
- Motorcycle flash light circuit
