Series regulated power supply circuit protection circuit 2
Source: InternetPublisher:toothache Keywords: Protection circuit circuit protection regulated power supply circuit series type Updated: 2020/12/20
It uses photoelectric coupler B
as the protection control component. This circuit has current-cutting protection and current-limiting protection
functions. When there is no resistor Ri in the figure, when the output is short-circuited
, U. . ≈o, the photoelectric coupler B does not work, the transistor VTz
is cut off, and the adjustment tube VTi is cut off, thus playing a current-cutting protection role
; when there is a resistor Ri, when the output is short-circuited, although B
is cut off, the base of VT2 is cut off due to Ri. There is a certain current, so that
VTi still has a certain current output. As long as the resistance value of Ri is appropriately selected
, a certain output current can be obtained, thus playing
the role of current limiting protection.
- Basic characteristics of power field effect tubes, how to improve the dynamic performance of power MOSFET
- How to Make a Soft Latch Circuit
- Schematic diagram of car cigarette lighter to USB power port
- Fabrication of multi-cell lithium battery charging circuit
- ISO113 circuit that can reduce power consumption
- Driving circuit that controls LED brightness using PWM signal
- Transformerless AC-DC constant current LED driver circuit
- Voltage-current converter constructed with XTR110
- Boost drive circuit composed of RT8450
- A small and easy-to-make fast charger
- Overview of 3.7v lithium battery protection board
- Overload protection circuit
- Relay inverse time overcurrent protection circuit a
- Structure and working principle diagram of various protection circuits e
- The structure and working principle diagram of various protection circuits a
- Motor overcurrent protection circuit
- Short circuit and overvoltage protection circuit for large current regulated power supply
- Thyristor overcurrent protection circuit 4
- Series transistor oscillation circuit
- Precision series regulated power supply circuit diagram
