Operational amplifier stabilized power supply circuit 2
Source: InternetPublisher:supremeOne Keywords: Operational amplifier regulated power supply circuit BSP output voltage Updated: 2021/05/12
This power supply uses few components but has good performance. When the input and output are electrically faulty
. When the input voltage of this power supply is 16-30V, the output voltage is 12V, the current is 1A, the internal resistance is <0.0010, the voltage stability
is 0.05%, and the peak ripple voltage is <25mV.
By selecting the appropriate voltage dividing resistor and winding or selecting the voltage stabilizing tube VS accordingly, the output voltage of the voltage-stabilized power supply can change within a wide range.
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- How to Make a Soft Latch Circuit
- 220V Remote Load Monitor
- Practical and convenient fax machine power supply control circuit
- What kind of circuit is a voltage regulator circuit?
- Visible laser digital control modulation driver
- Low cost and high performance LED constant current power supply
- Charging control circuit made by solar energy
- Adjustable regulated power supply with current limiting protection
- Power supply circuit that can reduce LM317 ripple
- Physiotherapy ventilator circuit
- soil content measurement circuit
- Poultry warming temperature control circuit
- Soil water shortage prompt circuit
- AC voltmeter
- Junction field effect transistor mixer circuit
- Crabo oscillator circuit
- Wireless microphone circuit
- superheterodyne radio circuit
- Guest arrival signal recognition circuit
