Adjustable regulated power supply circuit with saturable reactor
Source: InternetPublisher:狂妄火龙果 Keywords: Reactor regulated power supply circuit PLUSMN BSP Updated: 2021/02/23
The output of this circuit can be adjusted within the range of 1~30V and 0~1A. When the grid voltage fluctuates
±10%, the output voltage change is not greater than ±0.1% (±5mV), and the peak ripple voltage is not greater than 1.5mV. It achieves voltage stabilization by
adjusting the tube voltage drop to change the AC voltage regulating effect of the saturated reactor .
- Build a simple buck-boost regulator and test it on a breadboard
- In-depth analysis of DC-AC converter inverter
- Op amp power supply decoupling bypass measures
- Using CW34603 to form a circuit to change the polarity of the output power supply
- USB power socket using the car battery
- Electric bicycle battery charger circuit
- Practical constant current charger-----Constant current charger
- MAX1811 Lithium Battery Charger Production
- Circuit diagram explanation: simple switching power supply circuit diagram
- Homemade home inverter circuit diagram
- Bone hyperplasia treatment circuit
- Electric massager circuit
- Chicken supplementary light to increase egg production rate circuit
- Wien bridge oscillator circuit
- Inductive feedback oscillator circuit
- Double gate field effect transistor high frequency amplifier circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Guest arrival signal recognition circuit
- Power phase sequence display circuit
- Sine wave signal generator circuit
