One of the inductive electric test pen circuits
Source: InternetPublisher:红水杯 Keywords: Inductive BSP alarm Updated: 2020/10/19
Inductive electric test pens and alarms can respond to alarms at a certain distance from live objects. Carrying them with you can prevent
accidents caused by accidentally entering high-voltage areas or accidentally touching live objects. The sensitivity
test pen or alarm , that is, the reaction distance to the charged object, is generally required:
5 to 10m at 110 to 220kV, 2 to 5m at 35kV, 0.8 to 2.Sm at 10kV, and 0.8 to 2.Sm at 6kV. 0.5~1. 5m,
5-20cm when using 220V mains power. After users gain some practice, they can roughly estimate the voltage level based on the alarm distance. The circuit is shown in Figure 13-101. The applicable range is 50~35kV.
The sensitivity of the electroscope
is related to the small copper piece at the G terminal (sometimes it may not be used) and the adjusting potentiometer RP.
- TEC laser diode driver circuit
- A white light LED power outage emergency light
- USB powered portable light
- Use MC1455PIG to make automatic cycle light-emitting diode circuit
- Solar battery and charging circuit
- Electronic massage and acupuncture device circuit
- Microwave Doppler warning circuit
- Application circuit of CAT3606
- Telephone theft automatic notification device circuit diagram
- Large light emitting diode display circuit
- Motor forward and reverse control wiring diagram (2)
- Set timing circuit when power is on
- Ultrasonic blind pathfinder circuit
- Biogas concentration detection line
- Proportional frequency discriminator circuit
- Simple AGC circuit in transistor radio
- Audio function generator composed of ICL8038
- Double gate field effect transistor high frequency amplifier circuit
- OTL low frequency power amplifier circuit
- Sawtooth wave generator circuit (1)
