Thyristor-slip motor regulator system block diagram
Source: InternetPublisher:常思一二 Keywords: Thyristor motor regulator excitation Updated: 2021/03/01
The circuit is shown in Figure 16-95 to Figure 16-97. This electrode autoregulator has better performance. For example, a current output type bridge comparison circuit with high accuracy
and good linearity is used; an arc current differential negative feedback circuit (precursor) is used to make the
lead time and correction intensity adjustable without causing overshoot.
In the figure, BQ is the slip motor clutch excitation winding; TG is the tachometer generator, and BQTG is the tachometer generator excitation winding.
- Tutorial on making your own remote-controlled robotic arm
- Build a Smart Garage Door Opener Using a Raspberry Pi
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- How to make a wheeled self-balancing robot using ultrasonic sensors
- How to Make a Hot Tub Smart and Remotely Operated with a Raspberry Pi
- DC motor drive circuit composed of L293D
- Star-delta step-down starting control circuit for squirrel cage asynchronous motor
- Working principle of ZNB-S digital display intelligent motor protector control circuit
- Delay switch made with LM431
- Bicycle anti-theft alarm
- Pyroelectric automatic door control circuit
- Multi-channel patrol detection control circuit c
- fire smoke control circuit
- Synchronous motor excitation device circuit
- 7kW diesel engine thyristor voltage regulating circuit
- KGLF-31F3 automatic excitation device circuit a
- TLG-1-, 2, 3 type thyristor automatic excitation device circuit
- DC electromagnet strong excitation fast pull-in circuit 3b
- Magnetic detection excitation circuit
- Excitation circuit composed of PMM8713 (3)
