Several trigger circuits using resistor-capacitor phase shifting g
Source: InternetPublisher:三月小雨 Keywords: Trigger circuit resistor-capacitor phase shift BSP Updated: 2021/01/20
The trigger circuit introduced above for unidirectional thyristors is also applicable to bidirectional thyristors. Also listed below are some for bidirectional
circuits as shown in Figure 16-28. Figure 16-28 (a) and (b) are direct trigger circuits; Figure 16-28 (c) is a trigger circuit using a
bidirectional trigger diode; Figure 16-28 (d) is a trigger circuit using two light-emitting diodes connected in reverse parallel Trigger circuit; Figure
16-28 (e) is a trigger circuit using neon bulbs; Figure 16-28 (f) is a trigger circuit using two NPN diodes (such as 3DG6, etc.)
; Figure 16-28 (g) is a trigger circuit using The trigger circuit of two diodes connected in reverse parallel; Figure 16-28 (h) is the trigger circuit
using
a triode instead of the bidirectional trigger diode ; Figure 16-28 (1) is
the trigger circuit circuit.
- Design and selection of electric control valve system drive
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- Analysis of the working principle of car garage door lights
- Build a Smart Garage Door Opener Using a Raspberry Pi
- Build a glove-controlled robotic arm
- An automated model railroad layout project using a microcontroller
- Squirrel cage asynchronous motor reverse braking control circuit
- Simple phase failure protection circuit composed of intermediate relay
- Design and analysis of a four-bit remote control component capable of remote reset
- Magnetic door and window anti-theft alarm
- Excellent performance household inverter power supply circuit
- Analysis of rectifier circuit types and principles
- Pulse therapy circuit
- Peanut and melon seeds roasting machine circuit
- Crop anti-frost circuit
- Rural fish farming control circuit
- Rural vegetable greenhouse lighting circuit
- Poultry warming temperature control circuit
- Simple AGC circuit in transistor radio
- High and low frequency signal generator circuit
