Humidity control circuit using transistors
Source: InternetPublisher:aerobotics Keywords: Control circuit transistor BSP transistor Updated: 2020/07/07
It uses composite transistors VTi and VT2 as the control circuit and a humidity sensitive resistor RS
as the moisture detection element. When the ambient humidity is high, the relay KA is closed and the hot air blower M works to dehumidify. When the humidity drops to the
set value, KA is released and M stops working. At the same time, the microammeter PA (the panel scale is changed to humidity) can directly indicate the humidity
value.
Adjust the potentiometer RP to adjust the humidity set value.
- How to use a microcontroller to control a servo motor?
- Servo motor pin diagram/working principle/application
- Tutorial on making your own remote-controlled robotic arm
- Design of an autonomous plant watering system using ATtiny85
- Manual automatic air compressor control circuit
- Motor automatic cycle control circuit
- Working principle of ZNB-S digital display intelligent motor protector control circuit
- Motor self-starting circuit
- Design and production of wireless multi-location control switch circuit
- Ultra-short wave item left behind reminder alarm
- Ultrasonic blind pathfinder circuit
- Peanut and melon seeds roasting machine circuit
- Egg heating control circuit
- Farmland irrigation automatic control circuit a
- Frequency modulator composed of NE566
- Simple AGC circuit in transistor radio
- Audio function generator composed of ICL8038
- Series crystal oscillator
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- common emitter amplifier circuit
