Grain moisture detection circuit
Source: InternetPublisher:三岁就很酷 Keywords: Humidity detection circuit BSP humidity sensor voltmeter Updated: 2020/01/08
It uses a 555 time base integrated circuit Ar and a capacitive humidity sensor C as the moisture detection
element. C is actually made of two metal plates with a certain area, which are parallel and separated by a certain distance. When
grain with a certain humidity is placed in it, the multivibrator composed of 555 time base integrated circuit A will
emit different oscillation frequencies according to the humidity of the grain, and turn it into a DC voltage, which is measured by a DC voltmeter. PV (scale changed from voltage to
humidity) is indicated. As long as the capacitance of the flat capacitive humidity sensor changes by 10 t,F, the DC voltmeter will
indicate a change of about 2V.
In the figure, RP is the zero-adjusting potentiometer, that is, when no grain is loaded into the humidity sensor , adjust RP so that the indication of the voltmeter
PV
is ov.
- DIY a simple fire alarm
- Car ice warning circuit sharing
- Peripheral circuit of automotive motor controller power supply chip
- Tutorial for building a remote-controlled Arduino Air-Boat
- What is a RADAX motor?
- What are the challenges in designing a permanent magnet linear generator?
- Design and production of radio remote control fan stepless speed regulator
- Design and analysis of a four-bit remote control component capable of remote reset
- Design and analysis of voice control circuit
- Ultra-short wave item left behind reminder alarm
- Motor forward and reverse control wiring diagram (2)
- Electronic thermometer circuit
- Ultrasonic blind pathfinder circuit
- Fish farming thermostatic control circuit
- Broadband high frequency power amplifier circuit
- common emitter amplifier circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
- Three primary color display circuit
- Various signal generator circuits
- Home appliance repair signal generator circuit
