Zero trigger integrated circuit temperature control circuit 4
Source: InternetPublisher:常思一二 Keywords: Trigger integrated circuit temperature control circuit BSP Updated: 2021/03/20
It is a furnace temperature automatic control circuit using KJ007 zero-trigger integrated circuit. It has the characteristics of high temperature control accuracy, wide range,
high sensitivity and simple circuit. The power of the electric furnace can reach 4kW (single phase) and 12kW (three phase).
The temperature sensing element is a thermistor R with negative temperature coefficient. The entire device consists of power supply circuit, temperature control circuit and zero trigger
circuit. A three-terminal fixed integrated voltage regulator Ai is used to provide DC power, a 555 time base integrated circuit Az
is used as the temperature control circuit, and an I(J007 zero-trigger integrated circuit A3 is used as the trigger control circuit of the bidirectional thyristor V.
If used in a three-phase circuit As shown in the dotted line and the figure inside the dotted box, as long as three sets of identical zero- trigger circuits are used
. The maximum capacity of each phase bidirectional thyristor is 50A. If this value is exceeded, the output power of KJ007 must be expanded.
- Car ice warning circuit sharing
- Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
- How to Make a Simple Chicken Incubator
- DIY an electromagnetic levitation device
- An automated model railroad layout project using a microcontroller
- DC motor drive circuit composed of L293D
- Motor automatic cycle control circuit
- Starting method of asynchronous motor with external frequency-sensitive resistor
- Light-controlled circuit design and analysis
- Guanghua brand anti-theft doorbell electronic lock circuit
- Electric massager circuit
- Electronic anti-asthma circuit
- Agricultural spraying and insecticide control circuit
- Biogas concentration detection line
- Farmland drainage automatic control circuit
- DC ammeter
- Amplitude modulation circuit composed of MC1496
- Series crystal oscillator
- color discrimination circuit
- Sawtooth wave generator circuit (1)
