Temperature switch circuit 2
Source: InternetPublisher:通通 Keywords: Switching circuit BSP refrigerator Updated: 2020/06/05
It can be used as an automatic constant temperature control for food refrigeration boxes, keeping the temperature inside the box at
-8~-10°C.
The temperature measuring element uses a thermistor R with a negative temperature coefficient. . The measuring bridge is composed of resistors Ri, R2, R3 and wind. When
the temperature inside the box is higher than -8℃, the relay KA is released, the contactor KM is closed, and the refrigerator works. When the temperature inside the box drops to
-10°C, KA closes, KM releases, and the refrigerator stops cooling. When the temperature inside the box rises to -8°C again, the circuit automatically
flips over and repeats the above process, thereby keeping the temperature inside the box between -8 and -10°C.
Negative temperature coefficient thermistor R. Choose RR03-2 type, the resistance value is 2.4kn at 25℃.
- Analysis of the working principle of the sound and light controlled delay switch circuit
- How to choose the right level of integration to meet motor design requirements?
- How can we make the robot move precisely on a predefined path?
- Add one more component to improve the phase failure protection function
- Design and principle analysis of practical electric curtain remote control device
- IGBT modules block overcurrent by controlling the gate
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
- Design and production of no-load automatic power-off device for household power supply
- Motorcycle anti-theft device circuit design
- Car audio system anti-theft circuit
- Pulse therapy circuit
- Agricultural temperature control circuit
- Crop anti-frost circuit
- Rural fish farming control circuit
- Junction field effect transistor mixer circuit
- Integrated synchronous detector composed of analog multiplier MC1596
- Schiller oscillator circuit
- Crabo oscillator circuit
- Double gate field effect transistor high frequency amplifier circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
