One of the temperature switch circuits
Source: InternetPublisher:方世玉223 Keywords: Switching circuit BSP relay Updated: 2021/04/16
The temperature switch circuit uses a certain temperature value as a switch, so that when this temperature value is reached, the controlled
object is turned on or off. Its principle is the same as that of the temperature control circuit.
The circuit is shown in Figure 11-68. It is actually a BJWO-1 type transistor temperature relay . Adjusting the potentiometer RP can
change the measured temperature, that is, change the action value of the relay . The
negative temperature coefficient thermistor Rt can be selected from the MF51 type.
- Analysis of the working principle of car garage door lights
- Car ice warning circuit sharing
- Tutorial for building a remote-controlled Arduino Air-Boat
- How to Build a Touch-Based Color-Changing Plant Using Arduino
- Amplitude and phase detection leakage protection device designed and manufactured using PIC16C711A
- PIC microcontroller controlled remote anti-theft alarm circuit
- Ultra-short wave item left behind reminder alarm
- Precious home appliance anti-theft alarm
- Homemade anti-theft watchdog
- Car audio system anti-theft circuit
- Electronic thermometer circuit
- Pulse therapy circuit
- Inpatient pager circuit
- High-efficiency speaker circuit for rural stage
- Straw returning to field crusher circuit
- Particle clogging alarm circuit of wheat seeder
- Agricultural spraying and insecticide control circuit
- Double detuned loop frequency discriminator circuit
- Capacitive feedback oscillator circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
