Thermostatic control circuit three using 555 time base integrated circuit
Source: InternetPublisher:同住地球村 Keywords: Integrated circuit time base integration thermostatic control circuit relay Updated: 2020/10/03
It is an electronic thermostat circuit for plastic injection molding machines. It uses the intermittent heating principle. A multivibrator with variable duty cycle is composed of a
555 time base integrated circuit . The signal controls the electric heater EH through the relay KA and changes
the power-on time to achieve temperature control. By adjusting the potentiometer RP, the pull-in time of the relay
KA can be changed from 0 to 67 seconds, so that
the length of the energization time of the electric heater EH can be easily changed to achieve temperature control.
- Design of an autonomous plant watering system using ATtiny85
- How to set up a cheap beam break sensor control distance scene using a reflector
- A small improvement on the ordinary refrigerator motor starting circuit
- IGBT modules block overcurrent by controlling the gate
- Hydraulic control circuit design and analysis
- Design and analysis of a four-bit remote control component capable of remote reset
- Do-it-yourself trial production of phase failure protection device
- Electric vehicle battery charging protection circuit
- Amplitude and phase detection leakage protection device designed and manufactured using PIC16C711A
- Delay switch made with LM431
- Simple timing control circuit
- Photocell amplification control circuit
- Car window control circuit
- Chandelier control circuit
- PLC transmission line automatic reclosing control circuit
- The structure of Hisense KFR-25GW-06BP inverter air conditioner outdoor unit microprocessor control circuit
- Digital current loop control circuit
- Detection and control circuit of electromagnetic stove
- Thermostatic control circuit 2 using 555 time base integrated circuit
- Bath tank thermostatic control circuit
