Simultaneous merging route diagram
Source: InternetPublisher:风向西瓜 Keywords: Wiring diagram BSP generator wiring Updated: 2020/08/26
Since the vehicle is paralleled at the same time, the generator does not add excitation, and there is no voltage on the generator bus, only residual voltage (about a dozen volts), so
the operation is relatively simple.
As long as the speed (frequency) of the standby generator rises to a value close to the speed (or
frequency (the difference can be ±2.5%, not necessarily exactly equal), the standby generator will be closed. The main switch of the motor is quickly turned on to the excitation
, so that the standby generator can quickly be synchronized by the system.
The self-synchronous parallel connection is shown in Figure 7-9; the secondary wiring is shown in Figure 7-9.
- Model rocket launch controller circuit
- Design of an autonomous plant watering system using ATtiny85
- Use your smartphone to turn on/off the power in your home
- How to Build a Touch-Based Color-Changing Plant Using Arduino
- How can we make the robot move precisely on a predefined path?
- Add one more component to improve the phase failure protection function
- Motorcycle anti-theft device circuit design
- Homemade short circuit alarm device
- Precious home appliance anti-theft alarm
- Car audio system anti-theft circuit
- stuttering correction circuit
- Pulse therapy circuit
- Electronic anti-asthma circuit
- Crop anti-frost circuit
- Chicken supplementary light to increase egg production rate circuit
- Mixer built with analog multipliers
- Frequency modulator composed of NE566
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Three primary color display circuit
- Small current generator circuit
