Machine tool electromagnet suction cup undercurrent protection circuit
Source: InternetPublisher:难得正经 Keywords: Protection circuit machine tool electromagnet current protection Updated: 2021/07/30
It uses the TWH8751 power switch integrated circuit A as the control element
f= of the relay KA, so the action sensitivity is very high and the safety of the device is improved. The 24V DC power supply is step-down from the 110V power supply of the electromagnetic chuck
In the figure, Cr is the electromagnetic chuck, and K is the normally open contact in the electromagnetic chuck circuit. After K is closed, CT will work, and relay
KA will close to make the machine tool feed work. When the electromagnetic chuck current is less than 90% of the rated current (
f can be adjusted by the potentiometer RPi), the relay KA is released, the machine tool feed circuit is powered off at the same time, and the feed system stops working, thus avoiding accidents.
- How to Make a Simple Chicken Incubator
- DIY an electromagnetic levitation device
- Motor self-starting circuit
- Methods for Eliminating Noise of Brushed DC Motors
- Starting method of asynchronous motor with external frequency-sensitive resistor
- Add one more component to improve the phase failure protection function
- Design and principle analysis of practical electric curtain remote control device
- Design and analysis of wire control circuit
- Light-controlled circuit design and analysis
- Design and analysis of a four-bit remote control component capable of remote reset
- Overview of 3.7v lithium battery protection board
- Low voltage circuit breaker protection circuit c
- Thyristor silicon stack protection circuit c
- Thyristor resistance-capacitance protection circuit a
- Voltage type leakage protection circuit
- Overcurrent protection circuit for TH78H5 adjustable integrated voltage regulator power supply
- Alarm and protection circuit using operational amplifier
- Overcurrent protection circuit for generator low voltage starting a
- Generator longitudinal differential protection circuit b
- Small hydropower station control and protection circuit
