Solid state relay circuit one b
Source: InternetPublisher:张小哥 Keywords: Solid state relay relay circuit BSP Updated: 2020/07/24
Solid state (body) relay (SSR for short) is a contactless switch assembled from solid semiconductor components.
Solid-state relays have the characteristics of small control power, high reliability, strong anti-interference ability, fast action (response time of tens of microseconds to
10ms), long life (l012~l013 times), high withstand voltage, and large surge current resistance [(6 ~10)j. ] and a wide applicable voltage range
(any selection within 30-220V), it can be widely used in digital program-controlled devices, computer terminal interface circuits and other
occasions.
However, solid-state relays also have shortcomings, such as large leakage current, large contact voltage, single contact,
poor temperature resistance and overload capability, etc.
The circuit is shown in Figure 6-5. Figure 6-5 (b) and Figure 6-5 (c) use AC power supply. Their structures are basically the same, but
the component parameters are different; Figure 6-5 (a) shows a solid relay using DC power supply.
As shown in Figure 6-5 (b), the circuit consists of photocoupler B, trigger circuit (
composed of transistor VT, thyristor vl, and diodes VD2~VDs), switching circuit (bidirectional thyristor Vz), absorption circuit (resistance R, capacitor C) and The zero-crossing control
circuit consists of a four-terminal device.
- Model rocket launch controller circuit
- Design of an autonomous plant watering system using ATtiny85
- How to Make a Simple Chicken Incubator
- How to set up a cheap beam break sensor control distance scene using a reflector
- Working principle of one Xipu STR soft starter controlling two motors
- Motor self-starting circuit
- Methods for Eliminating Noise of Brushed DC Motors
- Do-it-yourself trial production of phase failure protection device
- Infrared blocking alarm device
- Water supply reminder after water outage
- Smoking Cessation Circuit
- Crop anti-frost circuit
- collector amplitude modulation circuit
- Parallel crystal oscillator
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Voltage-controlled voltage source second-order band-pass filter circuit
- superheterodyne radio circuit
- Three primary color display circuit
- Power phase sequence display circuit
- Sawtooth wave generator circuit (2)
