Low power power frequency inverter
Source: InternetPublisher:红水杯 Keywords: Power frequency inverter inverter power supply Updated: 2023/12/05
Here is a simple small inverter power supply. It can continue to power 25W, 35W and other small soldering irons or low-power light bulbs when the AC power supply is cut off. For emergency use.
Transistors T1 and T2 (BC547) form a square wave multivibrator and output a 50Hz signal. This complementary output is sent from the collectors of T1 and T2 to the PNP Darlington driver stage composed of T3, T5 and T4, T6. And connect the output to the push-pull amplifier stage composed of T7 and T8.
The secondary of transformer X1 is connected to the collectors of push-pull amplifiers T7 and T8 through terminals 12-0-12. The center tap is connected to a 12v battery (7Ah), and the primary sends out 220v AC power for small power resistive loads.
When in use, just close the switch S1, and the transformer X1 will send out 220v AC voltage at its primary end, depending on the size of the load. Adjust the battery capacity, T5~T8 radiator size, transformer size, etc.
- A very convenient small power supply circuit to share
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- Energy-saving motorcycle rectifier regulator
- Use pulse width modulation to get a precise output voltage
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- Switching power supply circuit composition and function introduction of each part
- An ultra-low output voltage regulator
- Electric bicycle battery charger circuit
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- Homemade Electric Bike Fast Charger
- Power supply circuit design optimized for digital light projectors
- Output 12V-10A power supply circuit
- Power supply circuit with multiple outputs (MAX1902)
- 2-phase CPU power supply circuit using HIP6302 and HIP6602 chips
- FGDF-3 three-phase low-temperature iron-plated power supply circuit
- Class A power amplifier power circuit
- Low voltage adjustable reference power circuit
- Industrial four-way programmable controller power circuit
- Power circuit for home appliance repair
- Common power circuits and applications 03
