Home > Power Circuits >Other Power Circuits > Power delay turn-on circuit
Source: InternetPublisher:吃掉星星 Keywords: delay circuit Updated: 2023/12/04
When designing electronic circuits. Sometimes you want the power to be turned on after a delay after closing the switch. For example, on a device with output, it is hoped that the device will work stably before outputting. In audio amplifiers, wait for the amplifier to stabilize before turning on the speakers, etc.
Figure 1 is such a delay circuit. The time base circuit 555 is used as a timer to drive the relay and delay for a period of time after the power switch is turned on. Connect or disconnect the circuit again. The delay time is determined by the capacitor C and the resistor R, when R=100kΩ. When C=10μF, the delay time is about 1.1 seconds.
When you do not want to use a relay, a transistor can be used to delay the turn-on of the DC voltage. The circuit is shown in Figure 2.
When the circuit in Figure 1 and Figure 2 is working. As long as the manual switch K is connected to the +12V power supply. The monostable circuit composed of NE555 works, and its ③ pin outputs high level. In the circuit of Figure 1, the relay contact K and Vout are connected to the +12v power supply for external loads: In the circuit of Figure 2, when the transistor T (PNP type) is turned on, its Vout is connected to the +12V power supply for external loads. Load usage.
Power supply delayed turn-on circuit NE555
