2.5 to 24V continuously adjustable regulated power supply
Source: InternetPublisher:常思一二 Keywords: Regulated power supply TL431 Updated: 2023/12/04
The picture below is a regulated power supply formed by using TL431 as the voltage reference and driving the field effect transistor K790. Its output current is large, reaching about 6A.
The working principle of the power circuit is as follows. After the 220V voltage is stepped down by transformer T, rectified by D1~D4, filtered by C1, and the voltage doubler circuit composed of D5, D6, C2, and C3, the voltage Vde=60V; Rw and R3 form a voltage dividing circuit; TL431 and R1 form a sampling amplification Circuit; 9013 and R2 form a current limiting protection circuit; FET K790 is used as an adjustment tube (can be used in parallel directly); C5 is used for output filtering. The voltage stabilization process is: when the output voltage decreases, the potential of point f decreases. After the internal amplification of TL431, the voltage of point e increases. After adjustment by K790, the potential of point b increases. On the contrary, when the output voltage increases, the potential of point f increases. , the potential of point e decreases, and after adjustment by K790, the potential of point b decreases. This stabilizes the output voltage. When the output current is greater than 6A, the transistor 9013 is cut off, thereby limiting the output current to achieve the purpose of current limiting.
The resistor R1 is selected to be 2w, and R2 is selected to be 5w. The parameters of other components are as shown in the figure, and there are no special requirements.
- LM350 adjustable voltage regulated power supply circuit diagram
- Is there any voltage at both ends of the current source? How to determine the direction of the voltage at both ends of the current source
- How does a step-down switching regulator use a series transistor or a power MOSFET?
- What effect does the copper coating on the bottom of the inductor have on the power supply?
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- Basic connection circuit of signal and power supply composed of ISOll3
- Simple and practical LED lamp driving circuit
- Constant current LED lamp driver circuit with soft start and anti-shock
- Parallel DC regulated power supply circuit diagram
- Adjustable regulated power supply with current limiting protection
- Use TL431 to make a simple charger circuit
- Use TL431 to make a TTL logic level detection circuit
- STR5412 power circuit
- DC 12V to AC 100V inverter power supply circuit design
- Portable device charging power circuit design
- Computer motherboard power circuit with +5.1V, -5V, +12V and -12V outputs
- High-precision voltage regulator using KTA431 (TL431)
- Remote control TV doorbell power circuit
- High-precision constant current source circuit diagram composed of TL431
- Overvoltage protection circuit diagram using TL431 precision reference source, etc.
