Use TL431 to make high-power adjustable voltage stabilized power supply
Source: InternetPublisher:风向西瓜 Keywords: Regulated power supply adjustable power supply Updated: 2023/12/13
The precision voltage reference IC TL431 is in a T0-92 package as shown in Figure 1. Its performance is that the output voltage is continuously adjustable up to 36V, the operating current range is as wide as 0.1.100mA, the typical dynamic resistance value is 0.22 ohms, and the output noise is low. Figure 2 is a typical application of TL431, in which the output voltage at both ends of pins ③ and ② is V=2.5 (R2 + R3) V/R3. If you change the resistance of R2, you can change the output reference voltage. Figure 3 shows a stable voltage power supply with a large output current (about 6A), simple circuit, and safety, using it as a voltage reference and driving an external field effect transistor K790 as a regulating tube.
working principle
As shown in Figure 3, the 220v voltage is stepped down by transformer B, rectified by D1-D4, and filtered by C1. In addition, D5, D6, C2, and C3 form a voltage doubler circuit (making Vdc = 60V), Rw and R3 form a voltage dividing circuit, T1431 and R1 form a sampling amplifier circuit, 9013 and R2 form a current limiting protection circuit, and the field effect transistor K790 is used for adjustment. tube (can be used directly in parallel) and C5 is the output filter circuit, etc. The voltage stabilization process is: when the output voltage decreases, the potential of point f decreases. After T1431 internal amplification, the voltage of point e increases. After adjustment by K790, the potential of point b increases. On the contrary, when the output voltage increases, the potential of point f increases. , the potential of point e decreases, and after adjustment by K790, the potential of point b decreases. This stabilizes the output voltage. When the output current is greater than 6A, the transistor 9013 is cut off, so that the output current is limited to within 6A, thereby achieving the purpose of current limiting. This circuit has no special requirements for other components except resistor R1, which is 2W, and R2, which is 5W. Its component parameters are shown in Figure 3.
- 12v high power battery charging circuit diagram
- Mobile phone universal charger circuit diagram explanation
- How to transfer electricity from the source to the energy storage system?
- A very convenient small power supply circuit to share
- Practical and convenient fax machine power supply control circuit
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- Recommended circuits for different power on times of LM4911
- Basic connection circuit of signal and power supply composed of ISOll3
- Principles and precautions of active discharge circuit
- Boost drive circuit composed of RT8450
- Importance of Voltage Supervisors and Output Topology Selection
- Power supply circuit design optimized for digital light projectors
- Industrial product promotion and shopping guide DC power supply circuit
- Three-way DC-DC converter circuit
- 2-phase CPU power supply circuit using HIP6302 and HIP6602 chips
- Low voltage adjustable reference power circuit
- Industrial four-way programmable controller power circuit
- Antenna amplifier synchronous power supply circuit
- Common power circuits and applications 02
- ±5V, ±12V power circuit B
