Correct and incorrect wiring of fluorescent lampsa
Source: InternetPublisher:赔钱虎 Keywords: Wiring fluorescent lights BSP switches Updated: 2020/05/14
The correct wiring of inductive ballast fluorescent lamps is shown in Figure 2-1 (a). The phase wire must be connected to the switch side.
Figure 2-1 (b) shows wrong wiring , because after turning off the switch
SA, the lamp is still powered,
which may cause an electric shock accident if the lamp is inspected or cleaned . In addition, both ends of the fluorescent lamp will emit low light, which will affect the service life of the fluorescent lamp .
In Figure 2-1, Cl is the reactive power compensation capacitor to improve the power factor, and sometimes it is not connected.
- TEC laser diode driver circuit
- Delayed gradual lighting with protection function
- Design and production of a practical electronic counting device
- Use NE555 to make a touch self-extinguishing table lamp
- Power outage emergency lighting
- Large light emitting diode display circuit
- Digital display multi-function thermometer circuit
- Fluorescent lamp dimming circuit composed of thyristors
- Touch lighting switch circuit three
- Reverse polarity drive circuit
- Motor forward and reverse control wiring diagram (2)
- strain sensor
- Straw returning to field crusher circuit
- Biogas concentration detection line
- Farmland irrigation automatic control circuit b
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- Proportional frequency discriminator circuit
- Double gate field effect transistor high frequency amplifier circuit
- OTL low frequency power amplifier circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
