Three working states of the triode - NPN type - amplified state
Source: InternetPublisher:睡不醒的小壮 Keywords: Transistor BSP collector Updated: 2020/05/22
Cut-off state:
When "≤0", the collector current is very
small, the transistor is equivalent to cut-off, and the power supply
voltage mound is almost entirely applied to both ends of the tube.
Amplification state:
"Gradually increasing from O, the collector current
J also increases according to a certain proportion. A small
change in I causes a large change. The transistor
plays an amplifying role.
Saturation state:
When the three-input tube is saturated, the voltage drop across the tube is very
small, and almost all of the power supply voltage E is applied to the collector
load. The larger the I port at both ends of the collector load resistor, the more
sensitive the control.
- USB powered portable light
- Practical sensitive light-controlled switch circuit diagram
- Use NE555 to make a touch self-extinguishing table lamp
- Lighting audio control circuit
- Mains undervoltage and overvoltage protection circuit 2
- Application circuit of CAT3606
- Two-way electronic music doorbell circuit
- Fluorescent lamp dimming circuit composed of thyristors
- Touch/wireless remote control dimmer light circuit diagram
- 6-digit cathode fluorescent triode display circuit
- Excellent performance household inverter power supply circuit
- High-efficiency speaker circuit for rural stage
- Agricultural small tractor lighting circuit
- Mixer built with analog multipliers
- Integrated synchronous detector composed of analog multiplier MC1596
- Simple AGC circuit in transistor radio
- Wien bridge oscillator circuit
- OTL low frequency power amplifier circuit
- Differential Amplifier Circuit
- Home appliance repair signal generator circuit
