High-voltage motor phase-to-phase short circuit and over-current protection circuitb
Source: InternetPublisher:方世玉223 Keywords: protection circuit piezoelectric motor short circuit Updated: 2021/09/20
It uses an inductive current relay. The instantaneous part of the relay is used as a current quick-break protection device
to protect the motor from phase short circuit ; the inverse time characteristic part of the relay is used as an overcurrent protection device to protect the motor from overload
The symbols in the figure are the same as before.
- Use your smartphone to turn on/off the power in your home
- Build a glove-controlled robotic arm
- How to Build a Touch-Based Color-Changing Plant Using Arduino
- How can we make the robot move precisely on a predefined path?
- A small improvement to the temperature and water level indicator alarm
- Controlling stepper motors with wireless remote control transceiver and PE-51 board
- Add one more component to improve the phase failure protection function
- PIC microcontroller controlled remote anti-theft alarm circuit
- Guanghua brand anti-theft doorbell electronic lock circuit
- Ultra-short wave item left behind reminder alarm
- Overview of 3.7v lithium battery protection board
- High voltage automatic protection circuit
- Three-phase motor phase failure transistor protection circuit
- Repeated ground protection circuit
- Structure and working principle diagram of various protection circuits h
- Switching regulated power supply circuit
- Stabilized power supply overcurrent protection circuit 3b
- Thyristor type overcurrent protection circuit 6
- One of the mains undervoltage and overvoltage protection circuits
- Diesel generator speed protection circuit
