High-voltage motor one-phase overload protection circuit b
Source: InternetPublisher:super_star Keywords: Protection circuit piezoelectric motor high voltage Updated: 2020/02/24
The so-called high-voltage motor generally refers to a motor with a rated voltage of i~iokV , and the capacity is generally above 150kW
. In order to ensure safe operation, relay protection devices need to be used for protection. The one-phase, one-relay overload protection circuit for
high-voltage motors is shown in Figure 4-49.
In the figure, TA is the current transformer. KA is the overcurrent relay, KS is the signal relay, QF is the circuit breaker, and
YR is the circuit breaker tripping coil.
- Analysis of the working principle of the sound and light controlled delay switch circuit
- Servo motor pin diagram/working principle/application
- How to remotely control devices using ESP8266 and LPC2148
- Build a Smart Garage Door Opener Using a Raspberry Pi
- How to build a simple tachometer using an infrared reflectance sensor
- Controlling stepper motors with wireless remote control transceiver and PE-51 board
- Add one more component to improve the phase failure protection function
- Do-it-yourself trial production of phase failure protection device
- A novel and practical power line anti-theft and cutting alarm circuit
- Bicycle anti-theft alarm
- Transistor leakage release protection circuit
- Low voltage blocking overcurrent protection circuit
- Overload protection circuit for high-voltage motors
- Thyristor silicon stack protection circuitb
- Thyristor resistance-capacitance protection circuit a
- Star connection motor phase failure protection circuit
- Thyristor type overcurrent protection circuit 3
- Mains undervoltage and overvoltage protection circuit three
- One of the mains undervoltage and overvoltage protection circuits
- Three-phase AC power supply phase sequence protection circuit
