380V factory motor low voltage protection circuit
Source: InternetPublisher:狂妄火龙果 Keywords: low voltage protection circuit motor voltage protection Updated: 2020/12/07
Low voltage protection is under voltage protection. When the grid voltage drops to a certain value, the motor automatically stops
running through low-voltage protection. The wiring of motor low-voltage protection should ensure that it can reflect the corresponding voltage drop, and
should not malfunction when the voltage transformer is disconnected.
When the motor is controlled by an AC contactor, since its coil can automatically release when the voltage is low, there is no need to install low- voltage protection .
Figure 4-48 shows the low-voltage protection circuit of a 380V factory motor . It consists of 4 voltage relays 1KV~4KV
. The operating voltage of 1KV ~ 3KV is set to ensure the self-starting of important motors , and is taken as 0.7U. ; The operating voltage of 4KV is
(0. 4 ~ 0. 5) Ue.
- How to use a microcontroller to control a servo motor?
- How to Make a Simple 2-Step Arduino Programmable Timer Circuit
- Peripheral circuit of automotive motor controller power supply chip
- How to Make a Simple Chicken Incubator
- How can we make the robot move precisely on a predefined path?
- Add one more component to improve the phase failure protection function
- Light-controlled circuit design and analysis
- Design and production of no-load automatic power-off device for household power supply
- Password type motorcycle anti-theft device
- Vibration anti-theft alarm circuit
- Resistive Neutral Leakage Protection Circuit
- Relay inverse time overcurrent protection circuit b
- Low voltage circuit breaker protection circuit e
- Confidential protection circuit for motors
- Thyristor silicon stack protection circuit c
- Thyristor silicon stack protection circuitb
- Delta connection motor phase failure protection circuit
- Structure and working principle diagram of various protection circuitsg
- Overcurrent protection circuit for generator low voltage start b
- Low voltage protection circuit using a low voltage relay
