Multiple waveform signal generator
Source: InternetPublisher:消失的歌 Keywords: Signal Generator Updated: 2025/08/15
The circuit, shown in the attached figure, utilizes a six-inverter digital integrated circuit, the 74HCU04, capable of simultaneously outputting rectangular, triangular, and sine wave signals, with a continuously adjustable frequency between 10Hz and 1MHz. A through F represent six inverters. A and C1 form an integrator, while B, C, R2, and R3 form a Schmitt circuit. When the Schmitt circuit's output signal is fed back to the integrator's input via R1 and RP1, a square wave oscillator is formed. The oscillation frequency can be approximately expressed as follows: fosc = 1/4 [(R1 + RP1) C1] (R3 / R2). Adjusting RP1 changes fosc. If the minimum oscillation frequency is set to 1, the oscillation frequency can be continuously adjusted between 1 and 20 times. The relationship between C1's capacitance and the oscillation frequency fosc is shown in the attached table.
F, R4, RP2, and R5 form a linear inverting circuit. Four diodes, VD1 through VD4, form a bridge circuit. This limits the top of the triangle wave, converting it into a sine wave. Adjusting the value of RP2 minimizes the distortion of the sine wave.
- Cell phone detector
- 10Hz - 60MHz Frequency counter
- USB voltmeter
- Transparent fluid detector
- Homemade metal detector
- Music logic test pen
- Humidity measurement circuit with temperature compensation
- Thyristor Tester Production
- Key points for designing industrial 4-20mA power supply and current collection
- IGBT drive circuit short circuit protection function test method 1
- Digital timer with one digit display
- Circuit diagram based on 50Hz time base signal generator
- Signal generator circuit with small distortion
- Single stage sound signal generator circuit
- Sound signal generator circuit using 555 time base circuit
- Voltage signal generator circuit with optical isolation
- Universal signal generator circuit for radio recorders and televisions
- Simple signal generator and tester circuit
- simple tv signal generator
- Flowmeter excitation signal generator
京公网安备 11010802033920号
